Internet disconnected 10 times today - help.
on 14-01-2023 08:46 PM
Message 4 of 4
Hello Support,
Today the internet has dropped out around 10 times which is certainly out of the ordinary.
I've checked all cabling which is good, the router logs are showing the following:
Line check not showing anything, RG14 area - Newbury.
TR-069 connectivity to (acs.talktalk.co.uk) has been closed
Serial NumberHardware VersionSoftware VersionGUI VersionSystem Up TimeMAC Address
N7200154N000388 |
FAST5364 3.00 |
SG4K100136 |
5.6.1 |
13d 11h10m49s |
48:D2:4F:09:86:05 |
Please let me know if you need any further info?.
Thanks,
Martin
Labels:
- Labels:
Connection
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
3 REPLIES 3
on 19-01-2023 08:11 AM
Message 1 of 4
How are you getting on? Do you still need assistance with this?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 16-01-2023 06:28 AM
Message 2 of 4
I'm sorry to hear this and I will take a look now. I've run a test on the line which hasn't detected a fault, however I can see quite a few re-connections on the line. Is there any noise on the voice service? Does your main socket also have a test socket please?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-01-2023 05:56 PM
Message 3 of 4
Hi @AbjectBlitz,
What does the LED on the router do when you lose connection (just wanted to double check that it was actually dropping its connection, as the 'uptime' in your details above is showing 13 days, but not sure if that model of router resets the uptime when the connection drops, or just when the router is power cycled).
If the white LED does go out, then flash white then amber/white, then if you have a landline phone can you check to see if that is working normally (i.e. you have a clear dial tone and no noise on the line).
If your master phone socket has a test socket inside it, then you could also try the router in there (via a microfilter), that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
The TalkTalk Support Team on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
- Broken phone line and just need a BT repair person to come and re-attach the cable in Broadband
- No Internet, Router not picking up DHCP address in Fibre
- Go Live Date Today - Internet Not Working? in Full Fibre
- Escalation of Poor Service Issue in Full Fibre
- AVOID TALKTALK: TalkTalk cancelling my transfer to a different broadband provider in Billing
