LAN LIGHT
1103andrewb
Message 6 of 6
LAN LIGHT GOES ON AND OFF
5 REPLIES 5
Message 1 of 6
Thank you for informing us! If you encounter any issues with your TalkTalk services or equipment, please feel free to reach out. We’re always here to help.
Thank you for getting in touch with TalkTalk. Wishing you a wonderful day.
Goodbye! 👋
1103andrewb
Message 2 of 6
Problem solved, faulty power adaptor.
Philile-TT
Message 3 of 6
@1103andrewb please answer @fr8ys so that we can further assist. @fr8ys thank you.
Phili
Message 4 of 6
Is this on your Router? Of so which model do you have?
Or are you on Full Fibre and your ONT box on the wall flashes?
Either way this is normal as it signifies data through your line?
Are you experiencing any issues with your connection?
If so, please give us full details.
Thank you.
Gliwmaeden2
Message 5 of 6
Staff will respond after the weekend, @1103andrewb.
