on 11-09-2025 04:41 PM
Hello. I'm currently facing a problem 've got no WIFI calling on my Samsung Galaxy S22 5G. Its all turned on , on my Phone. However when I go to my dads I get WIFI Calling straight away. He's with BT Broadband. Please could someone address this and fix the problem. Thanks.
on 12-09-2025 08:03 AM
Please use the below steps to try and connect.
Make sure Wi-Fi Calling is set to On. To switch off Wi-Fi Calling, set the toggle to Off.
on 11-09-2025 06:01 PM
Yes. I've currently reapted that stel so many times. Nothing has changed.
on 11-09-2025 05:49 PM
Thank you for this. Have you restarted your router with this currently affecting?
If not, kindly restart it in this way:
on 11-09-2025 05:42 PM
Nope, everything else is great!. Just WIFI Calling. Was working perfectly before but now I don't get anything.
on 11-09-2025 05:06 PM
Pleasure. Just a minor question @Jacobwebb1994. Apart from Wi-Fi calling, are you experiencing any problems with your internet connection, like dropped connections or slow speeds?
on 11-09-2025 05:02 PM
Thank you for the update. I've updated my profile for you guys.
on 11-09-2025 05:01 PM
Hello, yes I've just updated my profile for you guys.
on 11-09-2025 05:00 PM
Thank you for confirming this. I have removed the details you have provided on my end and will further investigate the matter for you. Please note in future, I will strongly advise for you to not post your private details publicly. Always include them to your profile.
on 11-09-2025 04:57 PM - last edited on 11-09-2025 04:59 PM by sabelo-TT
Hello, yes I'm currently a talktalk customer. My email address is *******
Date of birth *******
on 11-09-2025 04:54 PM
Hello there @Jacobwebb1994, thank you for making us aware of this as I do apologise for any difficulties that this may have caused to yu. Just to firstly double check, are you currently a TalkTalk active account holder?
If so, could you kindly update your profile and include details which will enable us to further locate your account.
