Connected without Internet...
WaRRioR1976
Whizz Kid
Message 4 of 4
Hello, TalkTalk peeps 👋🙊
Every few days I have an issue with one of my devices - Samsung Galaxy S22 - having connection problems. I'll try to get online and am unable then I'll check the phone Wi-Fi settings and it will say connected without Internet. This happens when connected to 5ghz band. I don't know if this happens with the 2.4 ghz band because I only have two or three devices and they usually connect automatically to 5ghz.
This isn't a one-off and it happens frequently. Obviously I don't know if it's a problem with my phone, router, or Wi-Fi. It's usually a strong stable connection and my router has been online for 17 days.
The router is a Sagemcom Fast 5364, software version SGK100208. As always, router logs are unavailable so I can't check them for any problems.
Does anyone have any idea what could be causing this?
Thanks in advance for any replies. 👍🥳🙃
I'm a drummer in a very well known band, I'm also a world class racing driver and crazy golf world champion 7 years in a row. Please note - I'm a bit of a dreamer and try and make my life sound more interesting than it is, so the above statement might not be true.
3 REPLIES 3
Message 1 of 4
Wi-Fi interference (nothing to do with electrical interference) can cause:-
  1. Slow speed,
  2. intermittent dropouts,
  3. breaks in the signal,
  4. no signal at all,
  5. or no internet access.
This can affect one or more devices. This can also lead to a permanent reduction in the speed of one or more devices. No ISP can be responsible for your local environment; this is mainly a byproduct of the popularity of Wi-Fi.
Generally speaking, the 2.4GHz band suffers far more from Wi-Fi interference than the much faster 5GHz band. However, the 2.4GHz band has a longer range than the 5GHz band and can penetrate walls better. This may very well change depending on your local area.
In other words, I offer a free, impartial analysis of your Wi-Fi network and will try to help you optimise your Wi-Fi connection. The next stage involves my sending out a guide to help you get important diagnostic information for me. I will then analyse these results for you and recommend changes to your router configuration, if required.
Message 2 of 4
@ferguson thank you fir the support. @WaRRioR1976 please answer above question.
Phili
Message 3 of 4
Do you notice this happening with other device also? And whilst you say it happens frequently, is it a long-standing, or recent phenomenon?
