on 12-12-2024 08:24 PM
I have had a problem with internet connection dropping since about Monday (9th December), even though at all times the router light remains white as if connected with service. This is for ALL wired and wireless connected devices. If I restart the router (the TalkTalk Wi-Fi Hub, leaving it for at least 20 minutes), the connection comes back, but it fully drops again anywhere between the following day or only after a few hours. We haven't changed anything about our setup. I last had to reboot the router at 7.30pm today.
I really need to get this resolved as my family work from home - I have already been through two live chats where they suggested a factory reset button on the back of the route. It lasted about an hour before the same issue returned.
I suspect an issue with the router is the problem, but resetting the router only helps for a short period. Are you able to help to get this fixed?
on 16-01-2025 07:03 AM
Great thank you.
on 15-01-2025 06:42 PM
No problems, I will swap the routers over the evening and report back how we get on. Many thanks.
on 15-01-2025 06:48 AM
Good morning,
Yes please as this would just help to rule out any issues with the current router.
on 14-01-2025 04:33 PM
Hi again Chris, not yet tested with a second route with this speed issue - we last used it the 'new' router that was sent to us when the problem with the full drop outs was happening before Christmas. The reason being I was a little reluctant to make the issue worse, but would it assist it I did try another router for a couple of days and report back again? Many thanks!
on 14-01-2025 03:05 PM
Thanks, and you tested with a second router?
on 14-01-2025 02:48 PM
Thanks for getting back to Chris and for the update. Yes, it does affect all devices whether wired or wireless. The other thing to note is sometimes it happens when there is lots of devices connected and other times when there may only be one...
on 14-01-2025 12:53 PM
Thanks for that. I've checked these time against the line history but nothing stands out. The error count remained low and no unavailable seconds. Do you see the drops in speed on both wired and wireless devices?
on 14-01-2025 08:38 AM
Good morning @Chris-TalkTalk ! As promised we tried to monitor the times of when we noticed drops in speed, and whilst not perfect, it was approximately as follows:
11/1/25, 4.20pm - download drop to around 10mb when I did a speed test
11/1/25, 8.40pm - generally slow, buffering on devices, etc.
12/1/25, 4.35pm - download speed down to around 8 - 10mb again, for a short period
12/1/25, approx 9pm - 11pm - generally slow, buffering on all devices, etc. and download around 34mb when checked
Hope this information is helpful, and happy to expand on detail if needed. Many thanks!
on 10-01-2025 02:02 PM
OK thanks, have a good weekend 🙂
on 10-01-2025 01:45 PM
No problems Chris, we will do that and report back. Many thanks!
on 10-01-2025 09:42 AM
Thanks for the information. Could you monitor the connection over the weekend and make a note of the times of any drops in speed, we can then check those against the connection logs to see if we can see any potential causes
on 09-01-2025 07:42 PM
Hi @Chris-TalkTalk , many apologies not to reply to your message until now. In summary it has been much the same as before Christmas, with no drop outs at all (which is great!) but perhaps once or twice a day the speeds dropping right off (wired and wireless) for a short period before returning to normal again. This is doesn't seem to correlate to the number or devices being used by the household either, so not sure what the cause is. I haven't wanted to fiddle too much (such as using the other router you sent us or the setting on the router itself) for fear of making the issue worse again, but any advice would be gratefully received. Many thanks.
on 02-01-2025 09:24 AM
Hi rachbt,
How has it been since your last post?
on 31-12-2024 09:07 AM
Many thanks @Anonymous
on 31-12-2024 08:26 AM
Good morning,
Thanks for the update and we'll check the connection stats in a few days to see if DLM has made any changes to the speed.
on 30-12-2024 09:43 PM
Good evening, as promised I checked the speed after resetting the router, and broadly has seemed to improve things. I checked it couple of times, to see if was consistent, it was initially 37Mbps shortly after the reset, dipped to around 34Mbps mid afternoon and is currently around 36Mbps download speeds. Tried it both wired / wireless, and was the same speed. So still a touch slower than before, but a definite improvement.
on 30-12-2024 12:28 PM
No Problem 🙂
Test and report back here when you can.
on 30-12-2024 12:26 PM
Hi @Anonymous, thanks for getting back to me, and I will try powering down the router now and see how we get on!
on 30-12-2024 08:38 AM
Morning rach,
I'm sorry to hear that your speeds have dropped. I've run a test on your line now and the sync speed looks consistent. Could you try powering down the router for a full 30 minutes and then retest the speeds again please as this will reset the current session and can often increase the throughput speeds.
on 27-12-2024 10:26 PM
Many thanks for the message and checking up on us! Glad to report still no drop outs in service, which is great. However, we are now experiencing quite slow internet speeds over the past few days, which we didn't really have before the problems with the drop outs. I did a speed test this evening whilst logged in to our talk talk account, and was running at around 33mb to the device (similar for both wireless and wired devices), but was as low as 8mb yesterday evening, even though the same test suggests the the speed to the router is around 40mb!
If there is anything you can help with this problem, it would be much appreciated. Many thanks.
