on 05-11-2024 10:48 AM
will my Fast 5364-3 router allow me to use a poe camera or will i have to use an extra power adapter for the camera ( Reolink due 3 )
I am NOT on fibre
on 05-11-2024 11:04 AM
Yes, I would expect it to work with the Ethernet connected directly to the router and a separate power source. If you buy a switch, you need to make sure it is a PoE switch.
on 05-11-2024 11:01 AM
The camera has two connection ports ethernet and power i wondered if i connect ethernet direct to router and power adaptor to the camera this would work
If i need a switch does this provide the power and not the router
on 05-11-2024 10:50 AM
No, you will need to purchase a PoE switch for this.
