Refer a friend
Robertroy
Message 2 of 2
I’m trying to refer a friend but can’t get to the right page to do it?
1 REPLY 1
Message 1 of 2
Do you use pop up or ad blockers? These can sometimes cause an issue, so if so disable them for the TalkTalk domian.
If not are you able to try another browser from your usual one?
Hope this helps.
