Remote access help needed
Kimsteven
Message 3 of 3
Can anyone help regarding allowing my IT dept remote access to my laptop.
Teamviewer doesnt give me a code that I need to provide the IT with due to security.
Or do I need to contact Talk Talk directly to deal with this.
Kim
Message 1 of 3
Great advice from @fr8ys there.
Let us know if it works. If not, make sure that your personal details including TalkTalk phone number and/or account number are complete on your community profile (click here) so that they can link your forum identity with your account and then they can look into this further.
Message 2 of 3
If you go to my account, you used to be able to turn Scam Protection off there, but I haven't looked for some while.
To do so the instructions were:
1 Log in to MyAccount
2 Select My Services
3 Select View HomeSafe settings
4 Select OFF and confirm when you see the pop-up window
You may also need to disable any pop up blocker you may have installed
Good luck.
