Remote desktop VPN connection not working
mrfreestone
Message 9 of 9
Good afternoon,
I am having the exact same issue as raised by user joeyfrees on 12-12-2022 at 09:35 PM (see quoted below). Your representatives fixed the issue by changing the version of the firmware on the router. Please could you do the same for me.
'I use a remote desktop VPN connection to access my files and programmes at work when working from home. Up until about 3 months ago I could access this without issue. Since then I have been unable to connect.
It is not an issue with the computer or remote desktop software as the remote desktop can be accessed on internet connections from other providers (Sky/Now) and older Talk Talk routers.
I have been advised by my company's IT department that it is likely an issue caused by an update to the Router's firmware/software which has changed VPN/remote access security settings (we have the latest Sagecomm Talk Talk Wi-fi hub).
The IT department have also advised that the Remote Desktop/VPN uses Port 1723 and runs on the PCP protocol.
Looking at the other posts similar to this, many advise turning off home safe settings/scam protection or changing the DNS server. I have tried both of these things and this hasn't resolved my issue.
Please could you look into this and provide a solution. Three separate calls to your customer service centre have not resolved this issue. If this isn't resolved we will have no choice but to leave the service for one which we can guarantee will work for this vital purpose.
Many thanks.'
8 REPLIES 8
Message 1 of 9
How have you found the connection?
Message 2 of 9
OK I'll start the update now, please don't switch off your router
mrfreestone
Message 3 of 9
Hi Chris, that would be ideal. I'm happy for you to go ahead with the update
Message 4 of 9
OK, I can update your firmware now if you like, it can take up to 10 minutes to complete. Please let me know if you'd like me to proceed with the update
Message 5 of 9
Hi mrfreestone,
I'll take a look at this now and get back to you
Message 6 of 9
Good morning, has this update been actioned? We are still having issues accessing the VPN.
Many thanks.
Message 7 of 9
Hi mrfreestone
Please can you also add your TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Skynet_TX
Message 8 of 9
Hi @mrfreestone,
The support team here on the community may be able to resolve this issue for you by updating the firmware on your Sagemcom to a version that is more reliable with VPN connectivity. However as it is currently the Christmas break you may need to wait a few days before they reply to this post to help.
