on 22-10-2022 10:43 AM
I've been experiencing repeated disconnects on various devices for some time now and was hoping that support could take a look at my router ( HG633 ). Examples of disconnects include the following :
Other thoughts and observations...
on 30-10-2022 11:47 AM
You do not need to be connected to any network to see an AP view, I don't know this analyser, is it under the networks tab? Alternatively, check the developer's website for it.
You have not said which network name (SSID) is yours. Judging by signal strength alone, is it the one called "Trip-and-Tiger"? If so it should not be on channel 4 at all. You can only use channels 1, 6 or 11 as they are classed as the only non-overlapping channels. It is currently interfering with channels 1 & 6 and they are interfering with you as well. You need to move it to channel 6, which looks about the best.
I may have some other recommendations when I see the AP view.
on 30-10-2022 11:05 AM
Hi Keith, here are screen shots as requested, I couldn't get an AP view for 2.4GHz as, despite my best efforts, I couldn't convince my wireless adapter to switch to that frequency. Hopefully you can determine the favourable channels from the channel view provided. The other networks in my vicinity are largely clustered together in two channels.
5GHz AP View
2.4GHz Channel View
5GHz Channel View
2.4GHz Time View
5GHz Time View
on 22-10-2022 04:38 PM
Please can you provide me a set of screenshots from your WiFi analyser, then I can check these for you & advise accordingly? Not knowing which one you are using, please can you get me:-
I will need to know which network(s) are yours.
Please post the screenshots that I have requested in my guide (no photos please they can be difficult to read as text can get out of focus when zoomed in), from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large. If they are too small, I will not be able to read them & although I can enlarge them, this puts the text out of focus. If you prefer PM them to me. If you do PM me, then please add a link in there to this thread, so that I can find it easily.
