Internet Problems Router
jajones1045
Message 5 of 5
I am wondering where I go to request a replacement router as mine has just stopped working, I have had the same router since I became a customer many years ago.
The internet disconnects multiple times in a day, and requires rebooting all the time.
I have reset the router and checked all the settings.
I spoke to an agent who also ran the tests, and found a fault outside my property which they sent an engineer to fix. But I’m still having the same problem.
4 REPLIES 4
Message 1 of 5
Hi @jajones1045
Thanks for the Private Message. The router is on its way, please allow 24-48hrs for this to arrive.
Please let us know how the connection compares with the new router.
Message 2 of 5
Hi @jajones1045
I'm just replying to your Private Message.
jajones1045
Message 3 of 5
Done
Message 4 of 5
Hi @jajones1045
Apologies for this.
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send you a replacement router.
