Replacement router - internet speed
on 04-02-2022 05:18 AM
Message 19 of 19
Replacement router has arrived and my internet connection is now stable (and not continually dropping off). My internet speed has now dropped to 18 - 10 mbps. Previously the old router was providing 23 -25 mbps. Can you:
1. Update the router firmware to the latest version
2. Tweak the router settings to achieve the previous speeds.
The connection to the house has shown to be capable of 25 mbps
Cheers
Dave Westlake
Education Consultant
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
18 REPLIES 18
on 18-02-2022 11:36 AM
Message 1 of 19
Hi WestyD
I'm glad to hear that the connection has remained stable.
The line is in sync at 20mb. Did the engineer advise if they reset DLM?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-02-2022 11:04 AM
Message 2 of 19
Hi Debbie,
Connection has been perfect, no drop off at all. The new router has solved that problem. Engineer tested the socket and it was showing 34 mbps. I have tried moving the router around to different points in the house but it still only giving 18 -20 mbps. No problems found with the internal network.
Its stable and always connects so that is a definite improvement.
Thanks for asking
Dave Westlake
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 17-02-2022 07:50 AM
Message 3 of 19
Hi WestyD
How has the connection been since the engineer visit?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-02-2022 11:27 AM
Message 4 of 19
Hi WestyD
Thanks for confirming your details.
I have arranged the engineer visit for 12/02 PM (1pm -6pm)
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-02-2022 09:21 AM
Message 5 of 19
Hi WestyD
I'm just sending you a Private Message to confirm some details so we can arrange an engineer visit.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 10-02-2022 02:38 PM
Message 6 of 19
No problem with an engineer visit as the only thing that has changed is the new router. Strange how the old router was giving 23 - 25 mbps and was constantly dropping off, the new router is giving 18 - 20 mbps but is providing a stable connections. The outages you were seeing was probably me switching off the router for 30 - 1 hour to get it to establish a new connection (as recommended by on one of the reply posts). I am aware that the BT engineer might incur a cost, however there is a history of problems with the feed to the property (despite this being a relatively new build), I'm very confident the problem lies with either the hardware you have supplied or the BT line in
Thanks for you help with this matter
Dave Westlake
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
10-02-2022 06:10 AM - edited 10-02-2022 06:10 AM
Message 7 of 19
Hi WestyD
I've checked again and I can still see re connections on the line so the connection must be dropping and this will affect the speed.
If you have tested with 2 different routers at the test socket then the next step will be an Openreach engineer visit.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 09-02-2022 07:32 PM
Message 8 of 19
The connection is stable now, its just slower than the previous router which was 23 - 25 mbps, but is now 18-20 mbps. The only change in the system has been the router. Is there anything you can do about this?
Dave Westlake
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 09-02-2022 07:48 AM
Message 9 of 19
Hi WestyD
I've checked the connection stats and I can see that the sync speed has dropped to 18.1mb.
There are re connections showing on the line. Is the connection still dropping?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 07-02-2022 07:39 AM
Message 10 of 19
Hi WestyD
Perfect, thank you 🙂
I will post back on this thread on Wednesday once I've checked the connection stats.
Thanks again.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 07-02-2022 07:35 AM
Message 11 of 19
Hi Debbie,
All done router now connected to the test socket and ready for testing 🙂
Dave Westlake
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 07-02-2022 07:21 AM
Message 12 of 19
Thank you for taking the time to reply 🙂
Dave Westlake
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 07-02-2022 07:12 AM
Message 13 of 19
Hi WestyD
Would it be ok to connect the router at the test socket and then leave it connected for 48hrs (without rebooting the router)
I can then check the connection stats again on Wednesday to see if DLM has made any changes to the line/profile speed.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 07-02-2022 07:08 AM
Message 14 of 19
Hi Debbie,
Connection is now stable and not disconnecting anymore. I did leave over an hour before installing the new router and I have repeated this since. Yes the connection speed seems to be between 18 - 20 mbps, this is down on the old router which delivered 23 -25mbps. Is there anything you can do about this? You changed the master socket coming into the property about 2 years ago and the engineer tested the incoming line which was showing 25mbps, so its defo a router issue.
Dave Westlake
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 07-02-2022 07:01 AM
Message 15 of 19
Hi WestyD
Your router has the latest firmware version. I have checked the connection stats and your line is in sync at 20.5mb.
Is the connection still dropping as I can see re connections on the line on 05/02? Or has the router been rebooted?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
04-02-2022 07:47 PM - edited 04-02-2022 07:51 PM
Message 16 of 19
Hi @WestyD,
The staff here probably won't be around until Monday now, however your new router should auto update to the latest firmware overnight within the first few nights of being connected.
If you have switched between different types of router did you leave over 30 minutes between switching the old router off and the new router on ?. If not, if would be a good idea to switch your new router off for over 30 minutes, then when you switch it back on it will connect to a brand new session in the street cabinet. If you swapped routers without leaving over 30 minutes 'down time' then your new router may well have reconnected to the session that was originally created by your old router, this can often mean the new router does not perform at its best possible speeds.
The staff here will also be able to respond next week to assist further if required.
If your old router was dropping connection a lot, this could also trigger the Openreach DLM system to reduce your speed in an attempt to stabilise your connection, if this is the case your speed should increase again within 48 / 72 hours if your connection now remains stable (it is fine to switch the router off for over 30 minutes to test the theory I mentioned above, as long as you leave it switched off for over 30 minutes the DLM system is clever enough to not count that as a dropped connection).
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 04-02-2022 04:14 PM
Message 17 of 19
Profile updated with phone number and email address as requested
Dave Westlake
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 04-02-2022 07:06 AM
Message 18 of 19
Hi WestyD
Please can you update your Community Profile to include your name and TalkTalk landline number, we can then look into this further.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
