Replacement router
exasperated2021
Message 2 of 2
I have a router that needs continuing power cycling to recognise a printer.  I have worked out it is not the printer by attaching one Brother printer, one HP and then buying another HP printer!
Afte about 5 minutes of no use, the router stops talking to the printer and will only do so when it is power cycled.   I think this is a router issue, but happy to be wrong!
Cheers
1 REPLY 1
Message 1 of 2
It could also be WiFi interference particularly if the printers only work on the 2.4GHz band. Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
