Router Disconnecting Losing
rrana1981
Message 6 of 6
Hi all,
Please can I get some support! I have had approx 100 disconnections from the internet over the last 14 days and to be frank really annoyed and has caused some problems on work meetings!
Been through usual diagnostics, router reset, talktalk doing all tests and telling me it's fine!
Quite frankly I'm getting irrated with this and the level of service.
Talktalk please sort this out asap. This is not acceptable levels of service.
Last year I faced the same issue and was updated to a 1.06t firmware upgrade on my Huawei Hub. Fast foward a year and it has started again!
Thankyou
R.Rana
5 REPLIES 5
Message 1 of 6
Hi Rakesh
Message 2 of 6
Hi Rakesh
The Sagemcom WIFI hub is on its way and you should receive this within the next 48hrs.
rrana1981
Message 3 of 6
Thanks Debbie, I managed to get through to a "John" at technical support who this time correctly managed to diagnose the issue correctly. A new wifi hub is being sent out per discussion on Saturday 2nd March. Could you please check that this has happened? Not sure if it a Sagem WiFi Hub (currently I have the Huawei one).
Rakesh
R.Rana
Message 4 of 6
Hi rrana1981
I will need to send you a Sagemcom WIFI hub. Would you like me to arrange this?
rrana1981
Message 5 of 6
My router model is Huawei DG8041W-2.T5
Current Software version 1.08t. Already have rung through to Customer Services and they advised me it was the Eero router being the problem that I have purchased to connect to the talktalk hub. I've disconnected and switched off the Eero router and I keep getting the disconnections.
The impact of this has been to my working day - i.e. disconnected from numerous Microsoft Teams calls which is very unprofessional.
R.Rana
