Router Playing Up
hatos13
Message 2 of 2
My Router was playing up. It is a WiFi Hub. The line kept dropping out. Fortunately I had a spare one which I bought from you some time ago and the internet seems to be working now.
I have had a few routers which have stopped working. Is there a better one I can buy from you?
1 REPLY 1
Message 1 of 2
Hi @hatos13
This will require TalkTalk to deal with your problem.
The TalkTalk Community has now moved to a peer-to-peer support model. This means that the TalkTalk team will no longer be here to support with queries. Don’t worry, there are plenty of ways to reach out if you need to speak to TalkTalk directly. For more details, check out the link here How to contact TalkTalk Broadband - TalkTalk Help & Support
