Router degradation requiring regularreset.
tomsky
Message 11 of 11
Every couple of weeks I need to reset my router when I see a degradation in speeds.
Resetting the router duly fixes the speed issue, but I've never experienced this before and I think the router may be faulty or have some bad firmware in it - it was issued 1.5 years ago.
Is there a known issue here and does TalkTalk offer a router equipment upgrade to fix this?
10 REPLIES 10
Message 1 of 11
I'm really glad to hear this. I'm just sending you a short survey via a PM.
Message 2 of 11
Hi Debbie,
It has indeed arrived and works well. Thank you!
Message 3 of 11
Hi tomsky
Message 4 of 11
Message 5 of 11
Great, thanks! I appreciate the swift response.
Message 6 of 11
Hi tomsky
Thank you 🙂
The router is on its way, please allow 48hrs for this to arrive.
Thanks again.
Message 7 of 11
Thanks - yes, they have responded.
Message 8 of 11
Hi Debbie,
I have updated my profile with name and landline number.
Message 9 of 11
Hi tomsky
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send you a replacement router for testing.
Message 10 of 11
Whilst these symptoms do not always mean that the router is at fault, due to its age, I have asked one of TalkTalk's support to pick your thread up and probably replace it for you.
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
