Router not working
QueenBee3
Message 3 of 3
My router-TALKTALK5A0A34 is not working. I need a replacement asap please.
Message 1 of 3
Hi @QueenBee3
Please can you add your name and TalkTalk landline number to your Community Profile, I can then take a look at this for you.
Message 2 of 3
That is your router's network name, not its make/model. You'll find that out on a label on the rear. Please can you give some idea as to what it is not doing?
