Second WIFI Extender not pairing
Thierry1
Message 4 of 4
I have had a Network Connector & WIFI Extender (DHP-W610AV) for a while and they work fine. I am trying to add a second WIFI Extender and trying to pair it with the same Network Connector. Unfortunately, it does not pair. I have tried everything from the setup and troubleshooting sections of the manual but to no avail. There was also something about going to http:/dlinkapXXXX.local./ but there is no access to the website! I have run out of options and don't know what to do. Kindly provide advice. Thanks
3 REPLIES 3
Message 1 of 4
Thanks @KeithFrench 🙂
Message 2 of 4
Hi Keith, many thanks for your time and your kind advice. It works! I must admit I had to try several times and I nearly gave up, but in the end it worked. Thanks again. I am not sure about the reliability of Talk Talk products though!
Message 3 of 4
I have never seen any documentation to support that method of connection at all. The URL quoted on the rear of the unit is for the web management interface & there is definitely not anything in there. What I would recommend you do, is to run them as two totally separate Extender/network connector pairs. Connect the two network connectors to two Ethernet LAN ports on the router.
