TP-Link AX3000 connection and setting change to talktalk router hub?
Shiero
Message 2 of 2
I am buying TP-Link Deco X50 AX3000 mesh wifi 6 system (3 pack). Would like to know if it will work with Talk talk router hub version FAST 5464-2.T4 or its setting need to be changed.
I have old talktalk router version FAST 5364-3.T8 and tried pairing with WSP button on new and old router. After pairing old router stays at flashing orange. Then I connect laptop to WAN port of old router , blue light with orange light comes and stay some time then it become soild orange with no internet connection. Once I remove ethernet cable it again flashes orange.
Please help and advise as signal is not strong in all bedroom and conservatory,it drops frequently.  Currenty managing with TPlink range extender but not much helpful.
Sanjay
1 REPLY 1
Message 1 of 2
This should work & with both the 5364 & 5464, I use this regularly with other mesh systems, but I do not have a Deco.
Just leave the Sagemcom in its default configuration, then connect one of its LAN ports via an Ethernet cable to the WAN port of your Deco. The IP network the Deco uses to hand out to your devices via DHCP must be on a different IP network to the Sagemcom (which defaults to 192.1.1.0/24). If your Deco already uses that network, then you could change the Sagemcom to put that on a different network, or change it on the Deco.
When you're happy, disable the WiFi on the Sagemcom.
