TalkTalk D-Link DHP-P326AV
Digger55
Message 8 of 8
I have just bought a 3rd TalkTalk DHP-P326AV powerline adaptor to add to the 2 I already had in use. Trying to find some information on setting them all up I couldn’t find anything for the DHP-P326AV but I could find a user manual for the DHP-P306/7AV, they look the same.
Are these the same item just rebranded for TalkTalk?
I have got all 3 talking to each other but would like to use the D-Link Powerline AV utility to set up the security for the 3 adaptors and update the Firmware / software if applicable.
Thank you
David
7 REPLIES 7
Message 1 of 8
You can't attach a photo, you need to use the Insert Photos button:-
Toolbar Insert PhotosToolbar Insert Photos
Still, unless you need to, as you say Ebay is full of them.
Message 2 of 8
You can't attach photos, you need to use the camera/image icon in the reply toolbar to upload them.
Digger55
Message 3 of 8
Hi I tried to attach a photo but would not upload. It doesn't matter as there are plenty on Ebay to look at.
David
Message 4 of 8
You just use the "Insert Photos" button on the forum editor's toolbar.
Digger55
Message 5 of 8
Hi The two original DHP-P326AV's were supplied by TalkTalk many years ago. The extra one is one of a pair of unused boxed I did buy on Ebay. I went for the same model number to make sure it was compatible. If the Current FW is Ver 106 then it doesn't need any update. But like you I couldn't find any information on the P326AV only P306AV. They all have the TalkTalk logo on the front.
Thank you for taking the time to look into this for me.
I did try to attach a photo but the site won't allow .JPG files.
David
Message 6 of 8
Hi @Digger55
@Anonymous has asked me to help you with this. I can only assume that from a Google search the DHP-P326AV is a very old product, it is not one I have ever heard of before. Only TalkTalk can update firmware for their products and as I am guessing that you purchased them from E-Bay or similar, I don't know how you stand with that. I have no idea if TalkTalk has any firmware updates for this product, but I will ask you.
Message 7 of 8
@KeithFrench - Is this something that you would be able to offer any advice on please?
