Internet dropping regularly
on 29-11-2022 03:10 PM
Message 38 of 38
My internet has been dropping for the past 3 weeks. It comes back on goes periodically but it seems to be off more that it's on.
Very low level activity seems to work such as skype messaging and whatsapp but browsing doesn't. The router maintains a white light and if I test the line it says I have a healthy broadband connection.
Currently restarting my router several times a day to try and kickstart it.
Have been on to talktalk support a number of times and it's all the same process and and never any improvement.
On all occasions they have said that the updating the firmware on the router has failed so I don't know if this is a related or not. Support don't seem overly concerned about it.
Was advised to factory reset it if the issues continue but no difference. Any ideas?
Labels:
- Labels:
Connection
Stability
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
37 REPLIES 37
on 07-12-2022 10:01 AM
Message 1 of 38
Hi Chris
Thanks for confirming your details.
I have arranged the engineer visit for 09/12 AM (8am - 1pm)
Thanks again.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-12-2022 01:53 PM
Message 2 of 38
Hi Chris
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-12-2022 01:52 PM
Message 3 of 38
Yes, that would be great thanks Chris
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-12-2022 01:47 PM
Message 4 of 38
Hi Chris
I'm so sorry to hear this.
The line test is clear, but I can see re connections on the line.
If the connection is dropping with 2 different routers, cables and filters at the test socket then the next step will be an Openreach engineer visit.
Would you like me to arrange this visit?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-12-2022 01:40 PM
Message 5 of 38
I'm now experiencing the same issues as I did last week. Internet is dropping again. I restarted the router this morning and it worked. I've been out and come back to no internet, tried restarting it again but it doesn't work.
As before, doing a connection test says I have a healthy broadband connection!
I've just taken the socket cover off and plugged directly into the test socket with a micro filter. It still doesn't work. The router has the white light on the front.
Any ideas?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-12-2022 11:42 AM
Message 6 of 38
Hi Chris
I'm so glad to hear this 🙂 Thanks for confirming.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-12-2022 11:40 AM
Message 7 of 38
All seems to be working perfectly! Thanks very much for your help
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
05-12-2022 11:22 AM - edited 05-12-2022 11:24 AM
Message 8 of 38
Hi Chris
Oh great that's the correct version, please can you retest your VPN connection?
Could you reboot the router first?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-12-2022 11:21 AM
Message 9 of 38
Hi Debbie,
Firmware version is showing as SG4K10002829t but there still doesn't seem to be any internet.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-12-2022 11:13 AM
Message 10 of 38
Hi Chris
Can you see which firmware version is now showing on the router?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-12-2022 11:01 AM
Message 11 of 38
Yes, the router is on. The white light is showing but the internet had dropped. On my mobile data currently. White light is still on the router
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-12-2022 10:56 AM
Message 12 of 38
Hi Chris
Is the router still switched on? I'm trying to push the firmware update through now.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-12-2022 10:27 AM
Message 13 of 38
Yes that would be great thanks. I'm on Windows 11
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-12-2022 10:25 AM
Message 14 of 38
Hi Chris
I can try a different firmware version, will it be ok if I do this in the next 30 minutes?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-12-2022 10:23 AM
Message 15 of 38
I found this online. I think that's the version my router is on.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-12-2022 10:20 AM
Message 16 of 38
Hi Chris
Are you using VPN windows 7?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-12-2022 09:59 AM
Message 17 of 38
Changed the VPN type to Point to Point (from automatic) and got the above error
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-12-2022 09:52 AM
Message 18 of 38
Hi Debbie,
Just the VPN client built into Windows
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-12-2022 09:47 AM
Message 19 of 38
Hi Chris
Can you confirm the VPN client you are using?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-12-2022 09:21 AM
Message 20 of 38
Hi Chris,
The router arrived yesterday and seems to have resolved the connectivity issues so far!
A new issue though... I can't connect to my work VPN this morning and I could with the old router. The message states:
Can't connect to the VPN
The remote connection was not made because the attempted VPN tunnels failed. The VPN server might be unreachable. If this connection is attempting to use an L2TP/IPsec tunnel, the security parameters required for the IPsec negotiation might not be configured properly
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
