Turn Off Wi-Fi Optimisation
R2223
Message 13 of 13
Could Wi-Fi Optimisation please be turned off again on my TalkTalk Wi-Fi Hub (Sagemcom Fast 5364) so that I can set the Wi-Fi channels manually. I had to reset the router so lost the existing setting. Thanks.
Having a simple toggle switch in the firmware is something TalkTalk really should consider adding given how many people have to ask OCE’s to turn it off.
12 REPLIES 12
Message 1 of 13
I've posted on your topic this morning.
Message 2 of 13
Please start your own thread, @Padwa69, to avoid confusion between accounts and this is an ongoing discussion between the OP and staff.
You need to return to the message board and click start a topic.
Also add your Talktalk phone number or account number in your Personal Information details. Go via your avatar; settings; drop down menu....Personal Information. SAVE CHANGES.
Staff will respond after the weekend.
Padwa69
Message 3 of 13
Hi I need wifi optimisation turned off for my router please?
Message 4 of 13
Message 5 of 13
Hi Debbie,
Thank you for getting back to me about the upcoming firmware. Much appreciated.
I am surprised it takes the developers over a year to release one firmware update. Most other routers out there get updates regularly every few months. It’s quite disappointing given how many major bugs these have.
Message 6 of 13
Hi @R2223
I've been advised that the new firmware is due to start rolling out around the beginning of August.
Message 7 of 13
Hi R2223
It's no problem 🙂  As soon as they confirm the official rollout date then I will post back here and let you know.
Message 8 of 13
Thank you for checking on the status of this for me Debbie.
Message 9 of 13
Hi R2223
I've been advised that new firmware for the Sagemcom hub should be available within the next 6 months (if not earlier)
They are working to release the new version ASAP.
Message 10 of 13
Hi R2223
No problem 🙂
I'm sure there is new firmware coming soon, let me just check and I will post back shortly to confirm.
Message 11 of 13
Thank you for the quick reply Debbie. Can I also ask is there any update about a new firmware version for the Fast 5364?
It’s been over half a year since bugs (like being logged out when navigating the UI and not being able to re-enable a Wi-Fi band after turning it off) have been reported and no firmware resolving these has been released.
Message 12 of 13
Hi R2223
Apologies, I've switched this off for you now.
I did feedback this back previously to request a feature so customers could switch this on/off themselves. I will pass on this feedback again, thank you.
