Using a TP Link TD-W9970 in modem mode with an Ubiquiti Edgerouter X
vext01
Message 2 of 2
I'm having a nightmare of a time setting up a TP Link TD-W9970 in modem mode with an Ubiquiti Edgerouter X on my TalkTalk Fibre 65 connection.
I can get the TP Link modem working as a router (i.e. *not* modem mode) using the pre-canned config for talktalk that the setup wizard offers, but I've not managed to get modem mode to the edgerouter working.
The only info I have from talktalk is this page:
https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383
I've tried all kind of things, but I'd really appreciate it if someone could confirm a) if the Fibre65 package is in fact considered a Fibre broadband connection (that would use plain old DHCP) or non-fibre broadband (which would require PPPoE).
If anyone else here has ever gotten an edgerouter working, I'd be really grateful for some help.
What I thought would work:
 - Set up TP Link modem into "bridge" operation (a.k.a. modem mode) with VLAN tag 101.
 - Connect edgerouter to WAN port of modem using either PPPoE or plain DHCP (tried both).
(When the TP Link modem was working as a router (not modem mode), I never gave it any credentials...)
1 REPLY 1
Message 1 of 2
If you set the TP-Link to Bridge Mode it will never work, it needs to be in modem mode. Bridge mode disables all routing functions & no IP traffic will be able to go from your private IP network out to the public IP network of the internet.
You can use your supplied TalkTalk router, still as a router in place of the TP-Link and just connect it to your other router. The TT one must be on a different IP network to your other router though & disable the TT's WiFi. You can probably do the same with the TP-Link, but I do not know this model. True, this creates a double NAT environment, but this is only an issue if you want to use port forwarding. Even then it is not difficult to configure.
