Issues with VPN
JSCL24
Message 54 of 54
Hi i'm having the same issues as many others with connecting a work VPN like https://community.talktalk.co.uk/t5/Broadband/VPN-issue/m-p/2923183#M844992
I have changed laptops, restarted the router, removed everything else from the network, separated SSIDs, held IP addresses, everything - any time I connect the VPN, it almost stops the internet and laptop running simple tasks but can still access websites.
Was on the phone to TalkTalk support but they hung up!
53 REPLIES 53
Message 1 of 54
Hi JSCL24
I'm sorry to hear this. If there is anything else that we can help with on the Community then please let us know.
Message 2 of 54
Sorry I thought i'd replied. It is on the medium setting.  My contract is coming to an end in a month so we're leaving TalkTalk.
Message 3 of 54
How are you getting on?
Message 4 of 54
Hi JSCL24
Please can you try changing the firewall level in the router settings to medium?
Message 5 of 54
I'm having to tether from my phone because TalkTalk have failed to resolve this. Ridiculous.
JSCL24
Message 6 of 54
Hello i'm still having major issues with this. Windows Explorer is crippled because the internet won't allow a connection to VPN through SonicWall NetEXtender.
Message 7 of 54
This is the test socket. Has the router always been connected here? What speeds are you seeing at the moment if you run a wired speed test?
Message 8 of 54
There is no test socket
Message 9 of 54
Ok thanks for confirming. This may be the re-connections that I can see. If the main socket does have a test socket, then it would be worth testing the microfilter and router directly at the test socket and retesting to see if this is still happening.
Message 10 of 54
The router was switched back to the old one at the start of the week, and then the new one a couple of days ago so you could test it, that's all. There may be a test socket as it's a standard BT Openreach socket, I can look this evening.
Message 11 of 54
I've run a test on the line now which is clear. The sync speed looks consistent however, I can see some re-connections on the line. Are you rebooting the router at all? Does your main socket have a test socket please?
Message 12 of 54
The problems with speed are intermittent - and the line has a tendency to drop out, losing connection, but the new router was particularly slow initially (screenshot below). If the line cuts out a lot maybe this is the issue?
Message 13 of 54
Ok thanks for confirming. Unfortunately, we only have the one router that we can send. I've spoken to my colleagues about this, but the VPN should work with this router and this particular firmware so it's strange that this is not working. I have just re-read through your topic and noticed that you mention that you have also experienced issues with the speed. Are you still experiencing issues with the connection that is separate to the VPN issue?
Message 14 of 54
Hi Michelle I have had several multiple hour conversations with IT where they look at the system to try to resolve it however it is not an issue with other ISP’s only Talk Talk (same with another colleague). Is there a different type of router available?
Message 15 of 54
I'm sorry to hear that your VPN is still not working. Have you been in contact with your IT department to see if they can offer any additional advice? Just to advise, we don't block VPN and this new version of firmware does resolve specific VPN issues.
Message 16 of 54
@Karl-TalkTalk nope, doesn't work still. Infuriating! No other provider has these issues. Totally moving to another ISP.
Message 17 of 54
I've updated the router, try the VPN now.
Message 18 of 54
New router is on but the vpn is not working still
Message 19 of 54
Glad all is working.
Message 20 of 54
Sorry technical issue (wrong cable!) it’s working now
