VPN no longer working
Lilyrose1978
Message 8 of 8
I'm hoping you can help me please!  Since the weekend, my VPN can't connect and my IT team have tested everything so they believe it's an issue with the TalkTalk router.  I'm using a Sagemcom-FAST5364.
It looks as though my router is running version SG4K100136, but the user dashboard says a software update is needed.  I've tried the support chat, who are very friendly but just keep directing me to reset my router, which hasn't helped.  I know can't log into my work VPN so will have to drive into my office tomorrow, but is there a way of getting this sorted please?
7 REPLIES 7
Message 1 of 8
Hi Lilyrose1978
That's great, thanks for letting us know.
Debbie 🙂
Lilyrose1978
Message 2 of 8
Thank you, it seems to be working now!
Message 3 of 8
OK thanks, apologies for any inconvenience
Message 4 of 8
Hi Debbie,
I've had to drive to my office today as I couldn't remote in from home, but I will test as soon as I get home and let you know.  Thank you!
Message 5 of 8
Hi Lilyrose1978
I've made a change to the firmware, please can you now retest?
Message 6 of 8
Absolutely.  Will I need to update anything?
Message 7 of 8
Hi Lilyrose1978
Will it be ok If I update your firmware this morning?
