WiFi Slow and DNS errors
Staffordgooner
Message 24 of 24
Last couple of days WiFi has slowed down from 50Mb to as low as 1MB. Impossible to run Teams calls. H/W S/W is FAST5364 3.00 / SG4K100136
mulitple DNS server connection errors in the log file.
Broadband is running at 50Mb with no drop outs
Firmware was upgraded today after factory reset.
Problem still there.
Please help?!?
Vince
23 REPLIES 23
Message 1 of 24
Hi Vince
I'm so glad to hear this 🙂
If you do experience any further issues then please let us know.
Staffordgooner
Message 2 of 24
Hi Debbie,
New router arrived, installed - all working well!
Vince
Vince
Message 3 of 24
Hi Vince
Thanks again.
Staffordgooner
Message 4 of 24
If no other changes can be made to this one, then yes please.
Vince
Message 5 of 24
Hi Vince
Apologies for this.
Would you like me to send another router for testing?
Staffordgooner
Message 6 of 24
No the 5GHz channel is not working ..
Vince
Staffordgooner
Message 7 of 24
OK - will do now
Vince
Message 8 of 24
Hi Vince
Ok, thanks for confirming this.
I've just switched the WIFI optimisation off on your line (now the new router is connected)
Could you retest again for me please?
Staffordgooner
Message 9 of 24
I renamed the channels to TALKTALK455B33 and TALKTALK455B3324. I did some more diagnostic last night. If I revert to factory setting, a couple of devices grab the 5GHz channel, but then within a couple of minutes they switch to the 2.4 channel and no devices are on the 5GHz channel. Once I split the SSID's I also notice that the 5GHz channel is not appearing in Wi-Fi network lists.
I have had to revert to the old router as the devices in my house need to see both named channels for my smart home to work. On the old router, connected now, I have 8 devices using the 5GHz channel, so I know it is something to do with the new router.
Vince
Vince
Message 10 of 24
Hi Vince
When you split the SSID's, did you rename the 5GHZ channel? I did the same the other day and I named one TT2GHZ and TT5GHZ, I could then see both in my wireless list.
Staffordgooner
Message 11 of 24
Hi Debbie,
I've had problems on one laptop today, so to be safe I have now swapped out the router for the new one. I have renamed it the same as my old router to save reconfiguring all connections. All devices initially connected at 2.4GHz, and now I have renamed this channel, the 5GHz channel is not visible at all to devices. It is setupto use channel 36, same as my old one.
Vince
Vince
Message 12 of 24
Thanks for the update. Yes of course, we'll check back in with you in a few days to see if the connection has remained stable.
Staffordgooner
Message 13 of 24
Hi Debbie,
The router has arrived, however, since you attempted the firmware update yesterday morning the service has been completely stable, so I'm a bit reluctant to swap out and have to reconfigure all my devices agan. Can I hang on to the new router for a few days to see if my existing one remains stable?
Vince
Vince
Message 14 of 24
Staffordgooner
Message 15 of 24
Thank you - will do
Vince
Message 16 of 24
Hi Vince
Let us know once the new router is connected and we can check the firmware again.
Staffordgooner
Message 17 of 24
Yes please Debbie
Vince
Message 18 of 24
Hi Vince
Apologies, I've checked again and the firmware update keeps failing.
Would you like me to send a replacement router?
Staffordgooner
Message 19 of 24
Debbie - an agent told me they did this yesterday after I did the factory reset they requested via chat. Is it not on the latest firmware?
Vince
Message 20 of 24
Hi Vince
I can update your router to the latest firmware version to see how the connection compares.
Please can you factory reset your router using the pin hole reset for ten seconds, I can then try and update the firmware.
