on 18-01-2026 12:56 PM
My Internet connection to the outside world seems to drop once a day now, steadly got worse over the last month. I thought I would go into the Router setup and review the operator logs. However, to my suprise the list is empty and I cannot see any logs. Is there a fix for this please? Software version: SG4K100208. I have full upload and download speed at the moment. Also, the router pages seem very slow to load, this is unusual. I have reset the router by turning off the power for 10 minutes. I do not use the wifi.
Thanks for your help
Marty 🙂
Thursday
Thank you so much for confirming your full address for me, I have ordered a free replacement router for you:)
Thursday
To staff
On 2026-01-30, 01:02 PM, Message 51 of 130
martynwjones Conversation Starter In response to Thabile-TT said:
not a WiFi issue. Same issue on Laptop which is wired connection.
Since he is using a wired connection, and the problem occurs there,
it is irrelevant, what happens if he now and then uses WiFi
Please stop asking him to test his WiFi, in order to have the router replaced.
Thursday
Thanks for your advice - I will try the steps below this afternoon
Thursday
Thank you though @KeithFrench, appreciate the help.
Thursday
I understand, I did provide advice on that as well above: If your main phone socket doesn't have screws, squeeze the sides of the faceplate to detach it
Thursday
The NTE5C's faceplate is not secured by screws at all. There are two tabs, one on each side. Push both of these in & carefully pull the face plate off.
Thursday - last edited Thursday
Hi there @KeithFrench, please note that the issue was picked up by the system however in this case I'll have @martynwjones test the socket and if we get the same results, we will order the router.
Please use the directions below to test the socket @martynwjones.
Here’s how to connect your router to your test socket:
Let me know how it goes and will take it from there.
Thursday
I beg to differ.
If the line test is OK and the router light keeps going amber when the problem occurs, it does not need an engineer.
The next step should be to move the router to the test socket behind the NTE5C's removable faceplate. If that is OK then the customer needs to get a new faceplate. If the test socket gives the same results, change the router.
Thursday
Based on the checks we've completed, it appears that the issue may be within your home setup. Here’s a summary of what we’ve done:
To assist further, we can provide additional guidance on checking your home setup.
Alternatively, if you'd prefer, we can arrange for an engineer to visit and ensure your setup is optimized for the best possible service. There is a fee of £75 for the engineer visit, but this will be waived if the engineer identifies a fault with Openreach or a fault with the router where a replacement is required (this does not include set up).
What would you like to do?
Book a TalkTalk Engineer
Get the in home check guide by email
Get the link for the in-home check guide
Resolve the issue myself
Thursday
A line test is currently underway. This checks the equipment used to provide the broadband service to your home - including the exchange, cabinet and line equipment.
This can take up to 8 minutes to complete. I'll let you know if this test finds a fault, otherwise I'll continue with further checks.
Thursday
no
Thursday
Do you currently have a telephone or handset connected to your landline service?
Thursday
Thank you, a line test is currently underway. This checks the equipment used to provide the broadband service to your home - including the exchange, cabinet and line equipment.
This can take up to 6 minutes to complete. I'll let you know if this test finds a fault, otherwise I'll continue with further checks.
Thursday
All good
Thursday
Please ensure:
1. The TalkTalk router is securely connected to the data (computer) port of a microfilter, and the microfilter is then connected to your master telephone socket.
2. An Ethernet cable is not connected to the WAN (red) port on your router.
3. Any devices connected to other telephone sockets in your house are connected to a microfilter, which is then connected to the telephone socket
Thursday
No damage
Thursday
Does any of the equipment appear to be damaged?
Thursday
NTE 5C
Thursday
I need to find out what type of master, or main, telephone socket you have so I can give the correct troubleshooting advice.
The master socket will be a white box on a wall, and is where the telephone line connects into your house from outside.
Please browse to https://community.talktalk.co.uk/t5/Articles/Your-guide-to-main-phone-sockets/ta-p/2205432 - this page shows you images of the different socket types so you can identify which you have.
Can you confirm what type of master socket you have please?
Thursday
As router checks haven't resolved the issue, the next step is to look at potential equipment damage and ensure it is connected correctly.
I'll guide you through the checks - ensuring any damage or setup issues that could have caused the disconnections from the Internet are identified and resolved.
If these steps don't resolve the issue then I'll look at other potential causes.
