on 19-06-2025 09:24 PM
Ongoing for months, repeated calls to tech department no resolution.
Talktalk wifi hub with external WAN modem.
Router version SG4K100208 with a separate wired ubiquity wifi access point to increase range.
Sometimes, the whole system grinds to a halt, sometimes its just the hardwired ports.
This issue is normally resolved by a router reset - but it is highly annoying happening at these times.
Mainly evening between 6 and 8pm but not exclusive to these times.
Lines tests and all the normal tests fail to find a solution.
I read of bugs with this version of router firmware. I cannot find the logs, nor can I find the speed to router information. ( I'm not convinced this has always been the case so has an update cause these issues ?) The 'home' icon in the gui doesn't work properly.
Note the regular low speed reports using the talktalk speed checker.
What steps can be taken to resolve this permanently?
on 23-06-2025 08:05 AM
Hi there @rowifi. Please do let us know once you are at home so that we can look into this for you. Thanks.
on 20-06-2025 06:16 PM
When you are back do try my suggestion of connecting at the test socket, just to rule out any problems with the faceplate.
Hope you're going somewhere nice! 🙂
on 20-06-2025 06:13 PM
Hello. I wont be home until next weekend so will need to wait until then.
on 20-06-2025 10:12 AM
Thank you for reaching out regarding the ongoing connectivity issues you are experiencing with your TalkTalk WiFi hub and external WAN modem. I understand how frustrating it can be to deal with repeated disruptions, especially during peak usage times.
Based on your description, it seems that the issues may be related to the router firmware or configuration, please let me know if you are currently home where the services are installed so we can look into this.
-Fez.
on 20-06-2025 10:03 AM
What more do you need?
on 20-06-2025 10:02 AM
The separate BT modem is plugged directly into the outlet marked Gfast.
It works fine 99% of the time. The falloffs are mainly same time in the evening.
Ive not looked at the lights on the modem .
on 20-06-2025 08:36 AM
on 19-06-2025 10:07 PM
Is this a G.fast service? If so, what are the modem lights telling you? Have you tried connecting at the test socket?
