Wifi-Hub - Constant Ticking Sound
ShanQ
Message 8 of 8
My Wifi-Hub is constantly making a low level ticking sound which is incredibly annoying as it sits near my work space.  Is there any way to stop this?
I've moved the router, restarted and factory reset it but still have the same problem.
7 REPLIES 7
Message 1 of 8
Message 2 of 8
Thanks Chris, you're a star! 🌟
Message 3 of 8
Thanks. I've ordered the router, it should be with you within a couple of working days
Message 4 of 8
That's all been updated, thanks Chris.
Message 5 of 8
Ok, can you please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Message 6 of 8
Hi Chris, yes please.
Chris-TalkTalk
Message 7 of 8
We can send a replacement router, would you like us to arrange this?
Anonymous User
