Wifi Problems on distance from router
brockhill
Message 4 of 4
No problems with wifi in my home until last Friday when  devices more than a few feet from the router started dropping out. Tried changing channels but that made no difference.
3 REPLIES 3
Message 1 of 4
How are you getting on? Do you still need assistance with this?
Message 2 of 4
Slow speed, intermittent dropouts, breaks in the signal, or no signal on some or all devices, might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a by-product of the popularity of Wi-Fi. This can happen at a moments notice, having been fine for ages.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
Chris-TalkTalk
Message 3 of 4
Hi brockhill,
Hi brockhill,
  • Name
  • Telephone number
  • Alternative contact number
