slow laptop speeds
neilsumner
Message 4 of 4
Service to the router is apparently good at around 70mb. My laptop is only getting around 6 though. Router at the front of the house, I am in the back. Small terraced house not a mansion. Even the TP link extender, it only shows 3 bars out of 5 at best. That was still the case trying it in the same room as the router. My laptop is a Sony Vaio. How can I check how well, or how to improve the signal from the router?
3 REPLIES 3
Message 1 of 4
How are you getting on?
Message 2 of 4
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
Message 3 of 4
Which make/model of router do you have?
Subject to that, our resident expert @KeithFrench may be able to help.
