on 30-11-2023 10:09 AM
When I click on the Settings Icon, then click all settings, all i get is a blank panel with the options down the left hand side. Clicking on any of these results in no action, just the blank panel. I'm trying to get to my Blocked Senders list as I'm not getting emails that I should. I use webmail, via Chrome
on 30-11-2023 11:45 AM
Hi stuers67
A Reset settings action in Chrome will usually fix the issue you're experiencing or try a different browser like Edge or Firefox.
Gondola Community Star 2017-2024
Like below to appreciate my post . . . Mark as solved Accept as Solution
