on 13-10-2025 11:49 AM
Answered! Go to Solution.
- Labels:
Wifi
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
on 24-10-2025 08:45 AM
Please confirm if you are still experiencing the issue, thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 16-10-2025 11:33 AM
It has been around for a while. I am waiting for the next firmware version to be released to see if it has been fixed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 16-10-2025 11:25 AM
Hi @KeithFrench,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-10-2025 08:03 AM
Thank you @KeithFrench for assisting.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-10-2025 06:14 PM
Many thanks for that, Keith. I’ll try what you suggest and report back.
Peter
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-10-2025 01:43 PM
Hi @Peter6734
This all depends on how you have set the WiFi network name (SSID) & password. The simplest way is to use an Ethernet connection & do it all via the Advanced Settings. If you have configured it via a Wi-Fi connected device, then this can easily end up like this. Plus, there is a bug in the firmware that when disabling & re-enabling a WiFi band, they will not come back properly.
The best thing to do is a factory reset by pressing the recessed reset button near the power connector of the Hub 2, whilst it is turned on, for about 20 seconds.
Once the hub is back up, log back into it & follow this procedure:-
First, go to Advanced Settings:-
Dashboard > See Wi-Fi Settings > Manage Advanced Settings
Now identify which Wi-Fi band the device that is to be used to change the SSID & passwords is connected to. Start by changing the SSID & password on the other band.
If the device is connected to the 2.4GHz band, then change the SSID of the 5GHz band first and then the 5GHz band password.
If the device is connected to the 5GHz band, then change the SSID of the 2.4GHz band first and then the 2.4GHz band password.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
