on 11-12-2024 12:10 AM
Since today, our router seems to be ocntmstantly crashing. I'm having to power cycle often to get it back up and running.
I'm able to connect to the router login page, but often it won't let me on saying 'can't communicate with gateway', or if I do get on, all settings appear blank!
Rebooting temporarily fixes..... My router has suddenly become very poorly for seemingly no reason!
Has there been a firmware push recently?
on 23-12-2024 10:17 AM
Hi Bruce @DrWig
Update on the fault - it was an issue with the firmware that Sagemcom have now worked to resolve.
on 19-12-2024 06:56 AM
on 18-12-2024 11:00 PM
That's great, thanks for letting us know. 🙂
on 18-12-2024 10:58 PM
Happy to report router and internet back to fully working.... Hooray.
Thanks for your help 😊
Cheers
Bruce
on 18-12-2024 09:01 AM
Thanks Bruce @DrWig
I'm not 100% sure what was causing this issue, I haven't had any information on this, only that the fix is going out this morning.
on 18-12-2024 08:55 AM
Will do. It doesn't seem to start really misbehaving until the evening (when the kids get back). I changed the DNS to google's last night. Was that the only change happening to the affected routers? I'm intrigued as to what the Talktalk DNS servers were doing to crash these particular routers! What were the findings (if you're allowed/able to share)?
cheers
Bruce
on 18-12-2024 07:05 AM
17-12-2024 10:24 PM - edited 17-12-2024 10:31 PM
Yea. Thanks for that link. Sounds promising! Fingers crossed 😊😊 I'll leave this new router plugged in, then 🤞
"Update 8:40PM December 17th 2024 - Our team are in the process of applying a solution to sall impacted Wi-Fi Hubs and aim to resolve this by tomorrow morning.'
on 17-12-2024 09:58 PM
I fear you may have been an early victim of what has become a known and widespread issue, see here:
https://community.talktalk.co.uk/t5/Service-Status-Dashboard/bd-p/service
on 17-12-2024 09:54 PM
Just a heads up, but I'm now getting exactly the same symptoms as before now. Internet cutting out, solid white night, can't log into router with 'Communication error with the gateway' and router version not visible on landing page type error 😒
Gonna switch back to my old HG635 for router.....
Cheers
Bruce
on 17-12-2024 12:49 PM
Hi Bruce @DrWig
That's great, thanks for confirming again. I've passed this information on to the engineers.
on 17-12-2024 12:43 PM
I've just had confirmation that my daughter's iPhone is NOT updated to 18.2 yet. That's the only iPhone/iOS device in the house.
cheers
Bruce
on 17-12-2024 12:36 PM
Thanks Bruce @DrWig
It's something they are looking at as a potential issue but not only looking at that, they are investigating many different things at the moment.
Thanks for confirming for me Bruce 🙂
on 17-12-2024 12:33 PM
Hi. It affected all devices on the network. My daughter has an iPhone (only one in the house. There is a Macbook too). She has likely updated to latest IOS....I've asked her.
I see that version of iOS came out on Dec 11th. Is one theory that this update is taking out the routers?
cheers
Bruce
on 17-12-2024 11:57 AM
Hi @DrWig
Quick question, when you were experiencing the no connection/white light issue, we know this will be affecting different devices, we just need to check if you do use any apple devices too and if these apple devices have IOS version 18.2 IoS release?
on 17-12-2024 09:27 AM
on 17-12-2024 09:24 AM
p.s. internet has stayed up so far, though, which is good 🙂
on 17-12-2024 09:23 AM
interestingly, it's letting me in again this morning, and correctly showing the version number at the bottom of the login screen:
Do you still need/want me to do a full reset?
cheers
Bruce
on 17-12-2024 08:41 AM
Hi @DrWig
Could you try factory resetting the new router using the pin hole reset for ten seconds, and then trying this again?
on 16-12-2024 11:49 PM
also, the logon screen isn't showing any firmware etc. details.....
