on 27-03-2025 12:16 PM
I recently received a FAST5364 as part of recontracting, while the wired connection is perfectly stable I have found that the WIFI on both channels has some issues with dropouts constantly for just a few seconds before then reconnecting and working fine.
I suspect this is due to Wifi Optimisation on the router, can I please have this turned off so that I can select a more appropriate channel?
Kind Regards,
on 27-03-2025 01:38 PM
Sorry, do you mean that you don't want my totally free help? I should have added this section to my first reply:-
The information below is provided by TalkTalk, for confirmation, please contact @Debbie-TalkTalk or @Lorrainef.
If you need further help or if we need to take any details such as personal information about your account like phone numbers, account numbers, etc, one of the TalkTalk team will jump in and help out.
on 27-03-2025 01:36 PM
Ah, nevermind then.
on 27-03-2025 01:35 PM
Hi @Anonymous
WiFi Optimisation can no longer be turned off. This is a business decision preventing all TalkTalk support staff from doing this.
The way forward is my unbiased analysis of your WiFi network. A lot of suspected WiFi Optimisation problems are actually caused by other underlying issues.
In other words, I will try to help you optimise your Wi-Fi connection. The next stage involves sending out a guide to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
