on 23-07-2024 12:38 PM
Could somebody please turn OFF the optimisation on my Fast5364 router. It continues to 'optimise' to the same channel as next door's BT hub causing interference and very slow speeds at the receiving equipment at the front of the house. I am continually having to manually reset the channel to get everything working properly.
on 24-07-2024 04:12 PM
Yes, I agree with that. Just let me know, whenever.
on 24-07-2024 04:09 PM
OK. I've now got it. There is no point in trying anything yet until the router 'optimises' itself back to channel 1
on 24-07-2024 03:36 PM
I have just sent it to you.
on 24-07-2024 03:35 PM
OK, I will resend it now.
on 24-07-2024 03:34 PM
There is no new message in that location since one dated 13 Jul
on 24-07-2024 03:27 PM
I sent you the PM yesterday at 10:17 as promised. To view your PMs, click on your Avatar at the top right of the page & click on the Envelope symbol:-
PMs
There, you should see my PM with a download link to my guide.
It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents.
on 24-07-2024 03:20 PM
Apparentl, I have a PM somewhere, but I don't know where. Also, where am I going to find a zip file from an analyser?
on 24-07-2024 11:01 AM
I have already sent you my guide.
on 24-07-2024 10:12 AM
So how do I go about getting an analyser report?
on 24-07-2024 10:09 AM
They will not switch it off, on your say do. However, with the analyser output I want you to collect for me, I can build a case to prove to them it is WiFi optimisation that is at fault. You know it is, but I need to prove it.
on 24-07-2024 08:51 AM
Would you please tell the devices team that not being able to switch off the 'optimisation' affects the functionality of my wifi reception and thank them for the time that I have to take in manually re-setting the stupid router to 'optimise' my usage. Could you advise 'Talktalk' that when they commission the next generation of modem to ensure it does not have an 'optimisation' facility. Could somebody understand that 'optimising' a transmitter is not a good idea as it is the ability of the receivers to receive the signal is what matters.
on 24-07-2024 08:27 AM
The devices team (not forum staff) simply don't allow switch off of optimisation any more as they claim it affects other aspects of functionality, @mjlew. So we are stuck with this now and Keithfrench has the best advice to offer you.
on 24-07-2024 08:23 AM
Not sure what you are trying to achieve here......Seems very complicated. The problem is very simple - next door's bt hub is channel 1. My wonderful router 'optimises' to channel 1 frequently and the result is interference, very slow speeds and loss of Rx at the front of my house. Manually changing the channel here (usually 6 or 11) solves all the issues. The simple answer is get rid of the 'optimisation' which, basically, is useless
on 23-07-2024 10:16 PM
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
on 23-07-2024 04:28 PM
Would you send me a copy of your guide please.
on 23-07-2024 02:41 PM
It is all working OK at the moment because I manually reset the modem to channel 6 this morning as it had, once again, 'optimised' to channel 1 (next door's BT Hub channel). I know what the problem is - it is the stupidity of something that optimises a transmitter to a channel that interferes with the receiving devices. The BT Hub is strong enough to use at the front of this house if I ever have a line outage. The frustration is having to do this nearly every day.
on 23-07-2024 01:09 PM
Hi @mjlew
@Debbie-TalkTalk has asked me to help you with your WiFi problems.
on 23-07-2024 01:03 PM
Hi mjlew
The desk-top doesn't look too bad from what I can see (but that's not to say you're not experiencing issues)
@KeithFrench provides really good advice on improving wireless performance. Could you help please Keith?
on 23-07-2024 01:00 PM
2 x desk-top. Ipad touch usually
on 23-07-2024 12:58 PM
Hi mjlew
Thank you. Which specific devices are at the front of the house?
