on 28-02-2025 08:13 AM
As noted in the post "New TalkTalk Wi-Fi Hub Firmware SG4K100208"
"Since the recent update to SG4K100208 within the routers menu structure Maintenance -> Logs is now empty regardless of the logging criteria applied."
I noted in my reply that I was experiencing the same issue.
@Michelle-TalkTalk asked that the additional info was added to a new thread
I also noted tha the router had re-started the regular 6 Second drop outs, which had plagued a previous update, then resolved in an update prior to SG4K100208.
I have a SamKnows box constantly monitoring the line. It is impossible to
check what is going on as, combined with this latest bug, there's no log to read!
Going to My Connection says all is fine!
It is also worth noting that the logs page has had a longer standing bug (also mentioned on thes forums) that often only page 1 can be read. Trying to access subsequent pages causes a crash, and needed you to re-login to the router.
Tuesday
Monday
Hi @Michelle-TalkTalk @Debbie-TalkTalk
Just to confirm all has been stable since the downgrade
Monday
I will contact our Devices Team to let them know the connection has remained stable.
Monday
Hi Michelle,
I've had a look but can't see how to contact the Devices Team. Can you advise?
Darren.
Monday
That's great, I'm so glad to hear that the connection has remained stable.
Please let me know here if you do experience any further issues.
Monday
Hi Michelle,
Ok.
Darren
Monday
Hi Debbie,
It was fine. No wi-fi dropouts. Solved, I think.
Thanks,
Darren
Monday
How's the connection been over the weekend?
on 07-03-2025 12:06 PM
Hi Darren,
If the connection is still stable over the weekend then we can feed this back to our Devices Team to see what they say/advise.
on 07-03-2025 12:04 PM
Hi Michelle,
After the roll back it was no better but last night I did a factory reset.
A few points: it didn't do a full hard reset as the router 'remembered' my previous IP assignments as I set them up again. It threw me back to the login screen many times and also froze. So, I not confident about how reliable it will be.
However, the wi-fi connections now seem ok. No regular dropping connections.
One question: how can I/you stop a subsequent update back to SG4K100208 (if you haven't already).
Thanks,
Darren.
on 07-03-2025 07:39 AM
I'm glad to hear this. The replacement router should come with a returns bag too.
on 07-03-2025 07:36 AM
So far so good 😊
Assuming the connection remains stable, with the software fix.
When the replacement router arrives, (Royal Mail say it's been delivered to my local Post office, but it wasn't there when I went to collect, so I've raised a ticket).
What should I do with it, contact you for a return label?
on 07-03-2025 06:12 AM
on 07-03-2025 06:11 AM
Hi Darren,
How has your connection been since your last post?
on 06-03-2025 12:16 PM
Hi Debbie,
I forgot to confirm that the firmware is now SG4K100206.
Darren.
on 06-03-2025 11:59 AM
Hi Debbie,
I didn't see the firmware change last night.
Today, it is probably worse (it took me 4 attempts to login here because the wi-fi kept dropping).
I did briefly see a log. Messages about connecting to, I think it was, SSIDs wl_priv and wl_video_5g.
I'll keep watching and I'll reboot the router.
Thanks,
Darren
on 06-03-2025 07:29 AM
Hi @gcotgreave
I will check in again with you tomorrow to make sure the connection has remained stable.
on 06-03-2025 07:26 AM
The line dropped at about the time the update (downdate!) SG4K100206 occured (as expected). When I got home there was no active internet. No connection possible over WiFi or Hardwire. No access to the 192.168.1.1 screen either. Rebooted twice, still nothing. Resorted to h/w reset button, and then had to manually enter all the device details passwords IPV4 reservations etc. Since midnight or so when I finished it has been stable, but that's not very long to say it's fixed.
Good news you can at least see the 1st page of logs in the maintenance screen again. (Still drops back to login screen if you try and see next page, but that's a known bug in SG4K100206)
on 06-03-2025 06:49 AM
Hi Darren @DarrenGraves
I've made the change to the firmware, please let me know how the connection compares.
@gcotgreave How was the connection last night?
on 05-03-2025 06:20 PM
Hi Debbie,
Fine with me.
Thanks,
Darren.
