Intermittent internet connection
MikeeV
Message 29 of 29
Since Friday 13 December my internet connection has become intermittent.  All Wi-Fi and Ethernet connections go down.  A line test shows no issues and the white light on the FAST 5364, running version SG4K100206, stays on consistently but the only way to reconnect is to reboot.  The GUI also crashes randomly back to the login screen whilst selecting options.  I've checked the logs which show nothing, other than the loss of DNS name resolution failures, but I assume this is a symptom not the root cause.
Could my hub faulty?
28 REPLIES 28
Message 1 of 29
Hi @MikeeV
Update on the fault - it was an issue with the firmware that Sagemcom have now worked to resolve.
Message 2 of 29
Hi @MikeeV
I'm so glad to hear this 🙂
I'm just waiting on information from our engineers to confirm what caused this issue.
I will post back here as soon as I have more information.
Message 3 of 29
Hi Debbie,
The connection has now been reliable for a couple of days. Would it be possible to share the details of the issue?
Thanks for your help
Mike
Message 4 of 29
Hi @MikeeV
This is the latest update on this fault.
Update 8:40PM  December 17th 2024 - Our team are in the process of applying a solution to all impacted Wi-Fi Hubs and aim to resolve this by tomorrow morning.
Message 5 of 29
Thanks Mike @MikeeV
I will let the engineers know.
Message 6 of 29
Hi Debbie,
It affects Apple, Android, Linux and Windows devices.
Mike
Message 7 of 29
Hi @MikeeV
QQ - Can I just check specifically what devices are affected when this issue happens please? Is it related to Apple devices only?
Which IOS version does the device have?
Message 9 of 29
Hi Debbie,
Will do.
Mike
Message 10 of 29
Hi @MikeeV
Oh great thank you. Please can you let me know if this fault happens again today (after the DNS change)
Message 11 of 29
Hi Debbie,
The DNS change has been made successfully.
Mike
Message 12 of 29
Hi @MikeeV
Could you also try these settings again whilst the connection is working. You may need to reboot the router first.
Change your router DNS settings to use Google DNS.
  • Open your web browser, type http://192.168.1.1 into the address bar and press Enter
  • Enter the username admin (in lowercase) and password (you'll find this on the removable settings card on the back of the Hub, and select OK
  • Select See internet settings
  • Select Manage advanced settings
  • Select TalkTalk WiFi Hub
  • Select DNS Tab
  • Make sure ON is enabled
  • Add Primary and Secondary DNS Servers ( Primary = 8.8.8.8  Secondary = 8.8.4.4 )
  • Select Apply
Message 13 of 29
Hi Debbie,
Apologies no, the router was rebooted last night at around 20:00 to reconnect. Will advise if it goes down during today.
Mike
Message 14 of 29
Hi @MikeeV
Sorry for the delay.
Is the connection still down this morning?
Message 15 of 29
Hi Debbie,
it had just gone down.
Mike
Message 16 of 29
Thanks Mike @MikeeV
The engineers are working hard to get this fixed ASAP. It would just be handy to have a live example before the reboot of the router.
Message 17 of 29
Hi Debbie,
understood. As it’s random will try to do so.
Mike
Message 18 of 29
@MikeeV  Could you let me know as soon as the fault occurs (without rebooting) I can then pass this straight over to the engineers.
Message 19 of 29
Hi Debbie,
The connection is currently up and has been all morning.
Mike
Message 20 of 29
Hi @MikeeV
Is the fault present at the moment? (no connection - white light)
Our engineers need to take a look whilst a fault is present?
