Any better router ?
jawatto
Message 4 of 4
i have had the same Talktalk supplied Sagecom router for at least 6 years.  Is there something which may be better, faster/more secure ?  I am on Fibre 35 and use Talktalk supplied powerline adaptors to connect Router to TVbox, wired connection direct from router to PC and wireless to my phone and tablet.
John
3 REPLIES 3
Message 1 of 4
No that is the standard router.
jawatto
Message 2 of 4
Thanks Keith.
It says version SG4K100174  so seems to be the one you mentioned.  No there is nothing specific amiss.  Just wondered as "tech" moves so fast if there was anything better.
Message 3 of 4
That is still the standard router & it should be running V174. Do you have any specific issues with it & if so, what are they?
