Constant orange blinking light
Scrimin
Message 3 of 3
Router constant flashing light, line checks are fine. Please advise.
Chris-TalkTalk
Message 1 of 3
Hi Scrimin,
If you still need assistance can you please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Message 2 of 3
Which router do you have?
What symptoms other than the flashing light are you experiencing?
Are you connected to the internet?
Is WiFi working ok?
If you can advise what you have tried such as turning the router off for a minimum 30 minutes and trying again, it will help support staff with diagnosing and issue, if there is one.
Thank you.
