Dodgy connection to fibre for all TVs
Tori3107
Message 9 of 9
All tvs loose connection. Very frustrating, as phones connect ok and the connection test says everything is fine. It’s been like this since it was installed. How on earth do I get through to talk talk to help?!
8 REPLIES 8
Message 1 of 9
Hi @Tori3107
How are you getting on?
Message 2 of 9
I have already offered you help, please see my previous post.
Message 3 of 9
hiya.
I’ve got an extra eero. The main tv is within 2meters of the main eero.
What do I do? I’m so mad with going to talk talk for fibre. It’s worse than any internet I’ve had before
Message 4 of 9
Message 5 of 9
Hi @Tori3107
Thanks for that. Slow speed, intermittent dropouts, breaks in the signal or no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
Tori3107
Message 6 of 9
Hiya, connecting via WiFi. Model is eero 6
Chris-TalkTalk
Message 7 of 9
Hi Tori3107,
Could you please answer Keith's questions and update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Message 8 of 9
How are your TVs connecting to the router, via WiFi, Ethernet or PowerLine Adapters? Which make/model of router do you have?
