Eero streaming issues
Markbennett
Message 3 of 3
I have recently upgraded to fibre 150 and was given an Eero 6 router. Since change I am having constant issues with streaming basic apps through ps4 and now Amazon fire tv. The tv/ PlayStation connect to the router, the router shows as connecting to the internet so no issues on the network whenever I have called but the streaming apps within the devices are constantly buffering.
I was happy with the black box router I had before as I personally don’t need a router with an app to control settings etc.
I have raised a number of times but dont seem to be getting actual troubleshoot information that can help me resolve- I wonder if anyone has anyone experienced similar and can advise on resolution?
I do not want to be turning my devices off/on 4/5 times before a connection is established and I don’t think the proposed solution of replacing the eero or purchasing a second device will resolve this.
Smaller devices such as phone, iPad, laptop etc never have an issue and all work perfectly all the time.
Message 1 of 3
Hi Mark,
How are you getting on?
Message 2 of 3
Whilst you can use your previous router (if it is the Sagemcom 5364) I can help you get your eero running much better.
Where in your property is the eero situated? Is it in a cupboard or out in the open & roughly how high is it off the floor? What electronic equipment is near it? Although it is difficult to predict the exact direction WiFi signals will propagate, are there any large metal objects, glass or water (tanks) that they might have to go through to reach your TV?
However, other factors should be investigated first. When this happens, what is the status displayed in the app for the internet connection? Do you have any wired connections & if so, how do they perform?
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. It is possible that you may also need to purchase additional eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
