WIFI optimisation and firmware SG4K100206
HonestJim
Message 6 of 6
Please could you turn off wifi optimisation on my line/router FAST 5464 please.
Since the recent firmware upgrade from SG4K100174 to SG4K100206 optimisation on the 5 GHz band now results in moving to higher channels than before. These are incompatible with older tablets such as my Huawei Mediapad M5 Lite. Recent channels 56 and 112 in spite of the channel settings on the router being In the range 36 to 48. Wifi optimisation before was an anoyance now its a show stopper.
Jim
5 REPLIES 5
Message 1 of 6
Hi HonestJim
No problem and apologies again that we couldn't switch off WIFI optimisation.
Message 2 of 6
Hi Keith & Debbie,
Thanks for the quick replies. Shame Wi-Fi optimisation can’t be disabled. Makes the ‘Auto’ option in the Hub’s channel selection somewhat redundant. Case closed.
Thanks again.
Jim
Message 4 of 6
Hi @HonestJim
@Debbie-TalkTalk has asked me to help you. There is nothing that was introduced in firmware V206 that will negatively impact on WiFi reception from V174. Most likely the levels of WiFi interference around you just happened to increase. I have done a number of investigations where WiFi optimisation would seem to be the cause, when often the level of WiFi interference is too great for this optimisation to be effective. However, I treat each case individually and provide impartial analysis.
Message 5 of 6
Hi @HonestJim
Apologies, we are no longer able to switch off WIFI optimisation on the line.
Our Community Star @KeithFrench offers really good advice on improving wireless performance. Could you help please Keith?
