FIBRE SPEEDS HAVE DROPPED BELOW GUARANTEED
DEGSY541
Message 16 of 16
Hi-today my speeds for fibre are very slow-below talk talk guaranteed-just tested now down is 23/up is 7-have switched router off for 30 minutes-to no avail.No noise on telephone line,and router is plugged directly into my master socket.Is it possible line needs a re-sync?
15 REPLIES 15
Message 1 of 16
Hi DEGSY541
No, the eero wont work with the Sagemcom hub, you would need to get an additional eero if you wanted to extend the wireless range.
DEGSY541
Message 2 of 16
Hi Michell,
So my eero should work with your 5364 modem router?If so what is the correct set up as I have tried and it will not give me an internet connection?
thanks,
Message 3 of 16
We have eero's and wifi hub routers but we wouldn't provide both together as it would be one or the other connected. If the eero range needs to be extended then we would advise adding additional eeros to the current eero set up.
DEGSY541
Message 4 of 16
Hi Michelle,
The 5364  modem router is the one supplied by talk talk.I believe you supply this with eero for some of your fibre plans,so it should work,are are the latest 5364 modem routers you supply with eero have adjusted settings?
Message 5 of 16
Good morning,
As far as I'm aware it's not possible to connect a different router to the eero. Are you experiencing slow speeds?
Message 6 of 16
Hi Debbie,
I have your 5364 modem router.How do I connect it to Eero 6?Do I have to change any modem settings,as it won't connect to internet?
thanks.
Message 7 of 16
Hi DEGSY541
That's great news, thanks for letting us know 🙂
DEGSY541
Message 8 of 16
hi Debbie,
thanks for getting back to me-all sppeds ok. now-back to normal--
Down--43.68 mbps.Up-10.16 m.b.p.s.
thanks.
Message 9 of 16
Hi DEGSY541
Sorry for the delay.
How's the connection/speed been since your last post?
DEGSY541
Message 10 of 16
Hi Chris,
re-tested today,switched router off agaoin for 30 minutes--all ok now--Down--43.68 mbps.Up-10.16 m.b.p.s.
thanks.
Message 11 of 16
OK thanks, have a great weekend 🙂
DEGSY541
Message 12 of 16
Hi Chris,
Will try tomorrow,as away from home now,will let you know, speeds after switching off again for half an hour.
Message 13 of 16
Could you try switching the router off for 30 minutes again please, I can't really see any reason why throughput speeds are so low compared to sync speed
DEGSY541
Message 14 of 16
Hi Chris,I measured speeds at my.desktop pc.hardwired ethernet cable to to router.The wireless speeds are at lot lower than they have been,download is in 20s.upload about 6.All used to be in 40s  for download,wireless and hardwired.If you got stated speeds at my router,do you think router output is faulty?
Chris-TalkTalk
Message 15 of 16
Hi DEGSY541,
Line test is passing and sync speed is 46.4Mbps, are your throughput speeds still low?
