Fiber 35 - no internet
MikeLMR
Message 11 of 11
The internet dropped out around 8pm last night. I have an aftermarket router and I can see a connection to the line and all the stats look healthy (SNR , attenuation etc. All indicate there is a line there) but we have no internet.
Getting the usual runaround with having to plug and unplug router and micro filters etc. But really just want the next level of tech support to take a look.
I am also currently not at home as I work remotely using the internet so I've had to come into the office for work instead 🙄
Have any of the network settings been changed that would have thrown my aftermarket router off? I'm fairly certain it's working as I mentioned above I can login as admin and check the settings and test the line etc. And all is well apart from the data not flowing
10 REPLIES 10
Message 1 of 11
I'm glad to hear this and thanks for confirming 🙂
MikeLMR
Message 2 of 11
Yes, it's all up and working as per normal again.
Message 3 of 11
Good afternoon,
Just checking back in to make sure that the connection is still ok since your last post?
Message 4 of 11
Thanks for trying this and I'm glad to hear that the connection is now working. We'll check back in with you in 24hrs to make sure that the connection is still ok.
MikeLMR
Message 5 of 11
I've come back from work early.
Tried the talktalk router and it connected ok but took a few minutes and the connection was very poor/slow.
I unplugged the standard router and tried my aftermarket one again and it is now working again with no changes this end. Again it was very slow at first but now the speed has picked back up to normal.
Message 6 of 11
The line test results are inconclusive. We would recommend testing with a different router just to rule this out as the next step would be to arrange an engineer visit if you've also tried connecting wired at the test socket.
MikeLMR
Message 7 of 11
I can try it, but I'm in a catch 22 situation where I'm not at home as I need the internet to work so I can't try all of these physical changes I have to try as I'm not there.
I can factory reset my router but I doubt it will help as it all looks fine and is reporting sensible numbers for the line test statistics etc
I guess I will have to wait until this evening to try these steps and hope I can resolve it otherwise I'm back to catch 22 tomorrow.
Message 8 of 11
Hi Mike
Would it be ok to try this TalkTalk router?
Did you also try factory resetting your current router?
MikeLMR
Message 9 of 11
My router is not in the test socket, we don't have one as I'm in a flat and the line comes into the garage and connects into our wiring there.
I do have a talktalk router and I haven't tried it yet,.but as I mentioned my router is showing it can see a line so there is a reasonable connection.
I am currently not at home due to the lack of internet but I don't see that as a barrier to getting this resolved as I don't believe my equipment is at fault.
Message 10 of 11
Hi Mike
I've completed a line test which hasn't detected any line faults.
Is the router at the test socket at the moment? Do you have a TalkTalk router?
