on 14-12-2023 07:39 PM
Just received an email from "info@consumer.talktalk.co.uk" stating that my average broadband spee is 67Mbps. My package is Fibre65.
If my average braodband speed is 67Mbps then at times it must significantly exceed that speed (simple estimate 90Mbps) to achieve the stated average. My actual broadband speed is usually around the 45 - 47 Mbps whenever I check it.
The message from TalkTalk also states that I have used 137 Gb of data over 3 months which seems a little high given we don't use Netflix or other streaming services but do have Freeview.
So my question is who and how are the figures in the email being derived and why do they differ significantly from my day to day experience.
on 18-12-2023 07:37 AM
OK, thanks Jerry. I've fed this back to the relevant team, apologies for any confusion
on 15-12-2023 07:09 PM
Ok, I've just received the same email myself. I guess all customers will be getting them in due course.
Apparently I've used "350Gb" of data in the last 3 months, so that could be personalised (I've no idea how much data I've used), but it also quotes the average speed of 67Mb/s (my speed is more like 35 Mb/s) so it looks suspiciously like they've just put in the generic marketing figure in there. Either the "your average broadband speed" it poorly worded or else they've meant to insert a personalised speed figure and it has gone wrong somehow, and neither of those 2 options would be anything new for TalkTalk.
I also notice that the data used figure near the top of the email is quoted in Gb (Gigabits) but the small print at the bottom of the email quotes calculations based on GB (Gigabytes) of data downloaded, so the whole thing is a bit of a mess.
In any case, TalkTalk's packages are all unlimited data and as long as my service is working and I'm getting the speed I expect, I'm not going to worry too much about it.
on 15-12-2023 04:35 PM
Hi Chris
Yes the data did look wrong - hence my initial post
Email was received 16:04, 14/12/23
Jerry
on 15-12-2023 01:03 PM
OK thanks. That appears to be specific information to your account looking at the wording but the data appears to be incorrect. And you've received it today?
on 15-12-2023 11:57 AM
Hi Chris
No, the email does not include either my account number or telephone number, just my first name with a greeting - see below:
on 15-12-2023 11:01 AM
Hi jerryf,
Does the email contain your landline telephone number and/or your account number?
on 15-12-2023 10:03 AM
Hi Allym
Below is extract from TalkTalk email to me regarding broadband speed.
If it is an average over the whole Fibre 65 customer base then it should say so rather than appearing to be personal to the addressee, especially as the email also states my personal data usage unless that is another generalised average.
My concern here is potential misleading presentation of performance rather than any problem with the connection itself.
on 15-12-2023 09:18 AM
Hi Jerry,
Line test is clear, connection looks stable and current sync speed is within the predicted range for your line
on 15-12-2023 06:04 AM
@jerryf ,
Average 67Mbps is the marketing figure often used to advertise the Fibre65 product. It's supposed to be the average speed of all customers on the Fibre65 package. I have no idea how or when they calculated that. I suspect the email is referring to that rather than a specific figure for your line. Perhaps you could copy and paste the wording of the email on here?
The only figure that really matters is the guaranteed minimum for your line which you should be able to see when doing a speed test via My Account and should have been advised to you when you took out your contract.
