How do I remove people from my wifi
FlorinM
Message 3 of 3
Got my own broadband in the house and 1-2 people Got access to the wifi, and I want to remove them but I don't know how.
bigkenny
Enlightened One
Message 1 of 3
also it might be best to change and keep secret the log in password for your router as if they can they might be able to get into your router settings and see the new wifi password
Message 2 of 3
The easiest way is to change your routers WiFi password. The only downside is you will need to log in on your own devices again.
For info on how to do this see here.
https://community.talktalk.co.uk/t5/Articles/How-do-I-view-or-change-my-Wi-Fi-name-and-password/ta-p...
Anonymous User
