on 28-02-2023 06:33 PM
I have been a TalkTalk customer for quite a few years and have what is probably an old D-Link DSL-3782 modem/router. I'd like to get my own OpenWRT router and put the TalkTalk router into modem mode. But from everything I gather this isn't possible.
Just wondering if anyone knows what my options are. Is modem mode actually possible? Or are TalkTalk likely to provide me with a newer model that does have modem mode? I'd rather actually get something running in modem mode rather than double NAT or using OpenWRT as an access point.
on 03-03-2023 08:51 AM
Hi @Snowman5395
I did exactly point out that it did not support modem mode.
I also offered a way of configuring it to work, as well as help on double NAT which I appreciate that you do not want to do. However, it is easy and as I pointed out it only has an impact if you want to use port forwarding.
I have not offered specific advice because I did not know which WiFi Hub you would get.
Please bear in mind that none of us, including @Debbie-TalkTalk or @Anonymous from TalkTalk, have control over the products that TalkTalk supply, we just support them.
You are free to use a 3rd party modem or modem/router of your choice.
on 03-03-2023 08:29 AM
@Debbie-TalkTalk wrote:Hi Snowman5395
I can see that @KeithFrenchhas offered some advice on this.
Hi Debbie,
Not quite. @KeithFrench very kindly offered some advice on double NAT'ing but this isn't really what I want to do. Modem mode would put the TalkTalk router into a sort of "pass through" mode for customers that don't want to user the router functions of the TT hub. It's a fairly standard feature with other ISPs and one that I see has been requested by other customers for a few years now.
Probably worth understanding this in case you get other customers request it so save on plastic waste of issuing new routers needlessly. But thank you for trying to help and thank you to the community members too @KeithFrench @martswain .
03-03-2023 08:20 AM - edited 03-03-2023 08:21 AM
@Snowman5395 please read post #9 from @KeithFrench
You cannot put ANY TT supplied router/HUB into modem-only mode.
on 03-03-2023 08:13 AM
on 03-03-2023 08:09 AM
Hi Michelle-TalkTalk,
Thanks for the follow up. I have just hooked up the new TalkTalk Wi-Fi Hub this morning. I can't see a way of putting it into modem mode in the administration console though (advanced or not). Do you have any instructions for this?
on 03-03-2023 07:48 AM
How are you getting on?
on 01-03-2023 09:38 AM
Sorry, @Snowman5395 no current TalkTalk router, including whichever one @Debbie-TalkTalk, has sent you supports modem mode. However, as I said before, I can talk you through configuring it to do what you want, but it will be a double NAT scenario. This is simple, as I said, to deal with.
on 01-03-2023 08:16 AM
Hi Snowman5395
Ah no problem 🙂
on 01-03-2023 08:05 AM
That's brilliant, thank you so much.
on 01-03-2023 08:04 AM
Hi Snowman5395
All done 🙂 The router is on its way.
Please allow 24-48hrs for this to arrive. Let us know how you get on.
on 01-03-2023 08:00 AM
Thanks Keith. Let's see if the new router that Debbie has kindly offered will allow modem mode. I'd prefer that so I can organise my LAN a bit more simply. Thank you though!
on 01-03-2023 07:58 AM
Brilliant thank you, done.
on 01-03-2023 06:48 AM
Hi Snowman5395
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send you a new router.
on 28-02-2023 09:48 PM
Modem mode is not possible, I do have a way around that, but it will create a double NAT scenario. However, that only becomes an issue if you are going to be using port forwarding, but depending on the configuration of your main router, it is easy enough to set up. I have done it many times & regularly use it.
