on 14-11-2025 10:52 AM
I seem to recall seeing support on here being able to provider customer with a new router. I need a new router please. The signal keeps dropping out constantly after a period of time. If I unplug it for a few days and then start using it again, it'll work for a while but will then start dropping the connection again.
Using a really really old router gets me online currently but slow.
on 14-11-2025 11:58 AM
You should be able to see the power light on the front of the router.
If this light is on, your router is receiving power.
Just to verify, is the router currently powered on?
on 14-11-2025 11:55 AM
Thank you, I can see that your Internet connection is currently offline.
This means that your Internet, WIFI, Email or TV Service will not work properly.
Shall we fix that now?
on 14-11-2025 11:54 AM
I work in the same room as the wifi and have even wired the connection to the laptop. The connections still repeatedly drop even when on the wired connection until I swap out the router.
on 14-11-2025 11:53 AM
Issue occurs everywhere? - Yes
Issue only occurs in one or some locations? - No
Issue is not with Wi-Fi? - No, it's the router...when I swap out to another old router it works again.
issue is with a single device? - No
on 14-11-2025 11:51 AM
on 14-11-2025 11:42 AM
Does the problem occur everywhere you try and use the Wi-Fi, or just in certain parts of the house - for example upstairs, or outside the house?
on 14-11-2025 11:41 AM
No
on 14-11-2025 11:38 AM
Do you have any active monitoring for life threatening health reasons which is solely dependent upon your TalkTalk Broadband or Telephone line?
For example a care alarm, lifeline, health pendant or fall detector.
14-11-2025 11:30 AM - edited 14-11-2025 11:32 AM
As per original post, the signal keeps dropping out constantly after a period of time. It drops, then reconnectes, drops, reconnects so that it's unusable. If I unplug it for a few days and then start using it again, it'll work for a while but will then start dropping the connection again.
14-11-2025 11:23 AM - edited 14-11-2025 11:24 AM
I am sorry to hear that, can you please confirm the issue you are currently experiencing is it slow speeds or dropping connection?
on 14-11-2025 11:20 AM
Plugged in now.
I've ran fault tests on my line the last few times I've experienced the issue but all have come back with no problems detected.
on 14-11-2025 11:19 AM
Can you please plug your router and we will start diagnostic checks.
on 14-11-2025 11:18 AM
I am, but currently thethered on my mobile as I've had to unplug the router.
on 14-11-2025 10:59 AM
Hi there @dooosuk I would love to assist you with your query, however we will need to complete diagnostic checks first to detect if there is a fault with your router. Are you messaging us from home?
