No internet
Kincavel
Message 14 of 14
I was recently upgraded to full fibre, which has been working fine. Came home yesterday to find only three green lights (no service light) on the ONT and a steady orange light on the router. Now awaiting an engineer visit after reporting the problem to TalkTalk.
Later in the evening, I noticed that the ONT was now correctly showing all four green lights, but the router still won't connect to the internet (I'm using my mobile data to write this).
Any ideas?
Kevin Snowdon
13 REPLIES 13
Message 1 of 14
Thanks for the update, glad you got it sorted. Apologies for the confusion with the engineer
Kincavel
Message 2 of 14
I was told that an engineer visit had been booked for 1PM today, so when nobody had turned up by 2PM, I rang TalkTalk to query the delay.
I spoke to a very helpful agent who, despite not having a technical role, had enough technical knowledge (and systems access) to fix the problem remotely! Turns out that my router profile was set to the wrong type of device (i.e. the profile was set to the router that has a voice port; mine doesn't) and needed to be corrected, after which normal service could be resumed after resetting the router.
It also turns out that an engineer visit had been requested from City Fibre, who had not received an answer from TalkTalk to their request for a time slot! The fault ticket is to be closed, which will also cancel the request for an engineer.
Kevin Snowdon
Message 3 of 14
if the router is working on the old FTTC line then it looks as though the router is OK so was worth trying 🙂
Kincavel
Message 4 of 14
Just tried it, and it works! Does that shed any light on the issue, or have I only succeeded in confusing things?
Kevin Snowdon
Kincavel
Message 5 of 14
Okay, will do, thanks. Something else has just occurred to me, though...
I posted a query a while back, essentially wanting to know what happens to the data element of my telephone signal now that I have full fibre. I was advised that this would eventually be switched off, and that I could meanwhile disconnect my phone line from the router. Assuming that the 'switch off' still hasn't happened yet...
Any point in quickly disconnecting the ONT from the router's WAN port and reconnecting the telephone cable to try testing the router  'the old-fashioned way'?
Kevin Snowdon
Message 6 of 14
Yes, please let us know how the engineer visit goes and if you then do need a replacement router please let us know
Kincavel
Message 7 of 14
Wouldn't hurt, I suppose, but I wonder if it might be better to wait until after the engineer visit I mentioned, which has been arranged for 1PM today, just in case the router turns out not to be the cause (I posted here thinking there might be a quick and obvious solution that made bothering an engineer unnecessary). I'll post an appropriate update here in any case.
Kevin Snowdon
Message 8 of 14
OK thanks, I can send another router to test with, would you like me to arrange this?
Kincavel
Message 9 of 14
Not sure if this helps or confuses, but my router, being fairly old, might be reaching the end of its useful life because there have been a few occasions recently, both before and since my full fibre upgrade, when I have had to restart the router after becoming 'connected without internet'.
Probably still doesn't explain the temporary absence of the ONT's service light, though.
Kevin Snowdon
Kincavel
Message 10 of 14
No, unfortunately.
Kevin Snowdon
Message 11 of 14
Do you have a laptop that you can connect directly to the ONT with an Ethernet cable?
Kincavel
Message 12 of 14
Sorry to appear dense, but what exactly should I connect directly to the ONT if I remove the router?
Just for info, the ONT and router are on opposite sides of the room, and are connected via a long Ethernet cable running around the room under the carpet. The router itself is located next to my PC tower and is networked using powerline adapters requiring only short lengths of Ethernet cable. If I have to start a removal/connection exercise, cabling issues may make this a pain.
EDIT: I could remove the ONT's Ethernet cable from the router's red WAN port and connect the cable directly to my PC in place of the cable that currently connects my PC to one of the router's yellow Ethernet ports. Is that what we're trying to achieve?
FURTHER EDIT: Even if that worked, I still wouldn't have a network. All it would prove is that the ONT is working, and surely the fact that the ONT is showing four green lights proves that without the need to start interfering with cables, etc.
Kevin Snowdon
Message 13 of 14
I'm sorry to hear this. Can I just confirm, if you remove the router and connect directly at the ONT, does the connection then work?
